[Swift-user] Re: swift guts doc with many diagrams and graphs
Michael Wilde
wilde at mcs.anl.gov
Tue Oct 14 09:49:32 CDT 2008
I think its spelled readData(), or was there another problem with it?
- Mike
On 10/14/08 9:34 AM, Alina Bejan wrote:
> yes, it worked, thanks.
> One more problem I noticed: 'readdata' does not work under Swift 0.6 (so
> I went back to use Swift 0.5). This might be a known problem, but
> thought I'd mention it.
> Alina
> Ben Clifford wrote:
>> Try log-processing r2293 (type 'svn update' in the log-processing
>> directory and check that it says you have r2293 or higher)
>> That fixes the problem for me.
>> On Mon, 13 Oct 2008, Alina Bejan wrote:
>>> Ok -- I am continuing this discussion on the user list.
>>> Here's where I put the .log file and the output of the swift-plot-log
>>> command
>>> on this file.
>>> http://www.ci.uchicago.edu/~abejan/swift-logs/
>>> Alina
>>>>> Please tell me if the instructions below are still accurate, or if
>>>>> anything
>>>>> changed -- basically the 'report-abc' directory fails to being
>>>>> created.
>>>> Probably the thing to do is make a report to eithe r this or the
>>>> users list
>>>> with the following: a URL or filesystem path where we can see the
>>>> log file;
>>>> the output of running swoft-plot-log.
>>>> This guide isn't intended to contain basic user instructions for
>>>> that - the
>>>> page that you looked at before (with the below instructions) is. Those
>>>> instructions that you pasted below should still work.
>>>>> "On a computer such as communicado, type:
>>>>> svn co https://svn.ci.uchicago.edu/svn/vdl2/log-processing
>>>>> cd log-processing/bin
>>>>> export PATH=$(pwd):$PATH
>>>>> swift-plot-log mylog-01234456-8922-abcdef.log
>>>>> This will give you a directory report-mylog-01234456-8922-abcdef/
>>>>> I usually then
>>>>> mv report-mylog-01234456-8922-abcdef ~benc/public_html/
>>>>> so that I can view it with a web browser at
>>>>> http://www.ci.uchicago.edu/~benc/report-mylog-01234456-8922-abcdef/
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
