[Swift-user] Re: swift guts doc with many diagrams and graphs
Alina Bejan abejan at ci.uchicago.edu
Tue Oct 14 09:34:37 CDT 2008
yes, it worked, thanks.
One more problem I noticed: 'readdata' does not work under Swift 0.6 (so
I went back to use Swift 0.5). This might be a known problem, but
thought I'd mention it.
Alina
Ben Clifford wrote:
> Try log-processing r2293 (type 'svn update' in the log-processing
> directory and check that it says you have r2293 or higher)
> That fixes the problem for me.
> On Mon, 13 Oct 2008, Alina Bejan wrote:
>> Ok -- I am continuing this discussion on the user list.
>> Here's where I put the .log file and the output of the swift-plot-log command
>> on this file.
>> http://www.ci.uchicago.edu/~abejan/swift-logs/
>> Alina
>>>> Please tell me if the instructions below are still accurate, or if
>>>> anything
>>>> changed -- basically the 'report-abc' directory  fails to being created.
>>> Probably the thing to do is make a report to eithe r this or the users list
>>> with the following: a URL or filesystem path where we can see the log file;
>>> the output of running swoft-plot-log.
>>> This guide isn't intended to contain basic user instructions for that - the
>>> page that you looked at before (with the below instructions) is. Those
>>> instructions that you pasted below should still work.
>>>> "On a computer such as communicado, type:
>>>>  svn co https://svn.ci.uchicago.edu/svn/vdl2/log-processing
>>>>  cd log-processing/bin
>>>>  export PATH=$(pwd):$PATH
>>>>  swift-plot-log mylog-01234456-8922-abcdef.log
>>>> This will give you a directory report-mylog-01234456-8922-abcdef/
>>>> I usually then
>>>> mv report-mylog-01234456-8922-abcdef ~benc/public_html/
>>>> so that I can view it with a web browser at
>>>> http://www.ci.uchicago.edu/~benc/report-mylog-01234456-8922-abcdef/
More information about the Swift-user mailing list
