[Swift-user] Re: swift guts doc with many diagrams and graphs
Ben Clifford benc at hawaga.org.uk
Mon Oct 13 21:12:11 CDT 2008
Try log-processing r2293 (type 'svn update' in the log-processing
directory and check that it says you have r2293 or higher)
That fixes the problem for me.
On Mon, 13 Oct 2008, Alina Bejan wrote:
> Ok -- I am continuing this discussion on the user list.
> Here's where I put the .log file and the output of the swift-plot-log command
> on this file.
> http://www.ci.uchicago.edu/~abejan/swift-logs/
> Alina
> > > Please tell me if the instructions below are still accurate, or if
> > > anything
> > > changed -- basically the 'report-abc' directory  fails to being created.
> > Probably the thing to do is make a report to eithe r this or the users list
> > with the following: a URL or filesystem path where we can see the log file;
> > the output of running swoft-plot-log.
> > This guide isn't intended to contain basic user instructions for that - the
> > page that you looked at before (with the below instructions) is. Those
> > instructions that you pasted below should still work.
> > > "On a computer such as communicado, type:
> > >  svn co https://svn.ci.uchicago.edu/svn/vdl2/log-processing
> > >  cd log-processing/bin
> > >  export PATH=$(pwd):$PATH
> > >  swift-plot-log mylog-01234456-8922-abcdef.log
> > > This will give you a directory report-mylog-01234456-8922-abcdef/
> > > I usually then
> > > mv report-mylog-01234456-8922-abcdef ~benc/public_html/
> > > so that I can view it with a web browser at
> > > http://www.ci.uchicago.edu/~benc/report-mylog-01234456-8922-abcdef/
More information about the Swift-user mailing list
