[Swift-user] Re: swift guts doc with many diagrams and graphs
Alina Bejan abejan at ci.uchicago.edu
Mon Oct 13 20:40:45 CDT 2008
Ok -- I am continuing this discussion on the user list.
Here's where I put the .log file and the output of the swift-plot-log
command on this file.
http://www.ci.uchicago.edu/~abejan/swift-logs/
Alina
Ben Clifford wrote:
> On Mon, 13 Oct 2008, Alina Bejan wrote:
>> Please tell me if the instructions below are still accurate, or if anything
>> changed -- basically the 'report-abc' directory  fails to being created.
> Probably the thing to do is make a report to eithe r this or the users
> list with the following: a URL or filesystem path where we can see the log
> file; the output of running swoft-plot-log.
> This guide isn't intended to contain basic user instructions for that -
> the page that you looked at before (with the below instructions) is. Those
> instructions that you pasted below should still work.
>> "On a computer such as communicado, type:
>>  svn co https://svn.ci.uchicago.edu/svn/vdl2/log-processing
>>  cd log-processing/bin
>>  export PATH=$(pwd):$PATH
>>  swift-plot-log mylog-01234456-8922-abcdef.log
>> This will give you a directory report-mylog-01234456-8922-abcdef/
>> I usually then
>> mv report-mylog-01234456-8922-abcdef ~benc/public_html/
>> so that I can view it with a web browser at
>> http://www.ci.uchicago.edu/~benc/report-mylog-01234456-8922-abcdef/
More information about the Swift-user mailing list
