[Swift-user] debug log not being produced
Michael Wilde
wilde at mcs.anl.gov
Sun Mar 30 07:48:24 CDT 2008
Its possible that using Java 1.4 is not the solution after all.
The tests I ran using Java 1.4 were done using "ant dist" rather than
the provider-deef.
Now I've rebuilt swift and falkon, with Java 1.4, and I once again have
the problem of no swift log being produced.
Its possible that the problem is in fact that building swift with
provider-deef is causing the no-log problem.
I'll explore further.
- Mike
On 3/30/08 5:51 AM, Ben Clifford wrote:
> what does 'which swift' output for you on that machine?
> On Sun, 30 Mar 2008, Quan Tran Pham wrote:
>> Hi,
>> I tried to playing with different Java version for a while, but still
>> cannot make Swift output the log on tp-login2 (Java 1.5 and Java 1.4).
>> Should I rebuild ant as well? Everything else looks ok with Swift over
>> Falkon.
>> Thanks
>> Quan
>> On Sat, Mar 29, 2008 at 7:58 PM, Ioan Raicu <iraicu at cs.uchicago.edu> wrote:
>>> Hi,
>>> The fix for Mike on the BG/P was to switch from Java 1.5 to Java 1.4.
>>> Not sure if this will also fix your problem, but its worth a try.
>>> Falkon will compile just fine with 1.4 (don't forget to do
>>> falkon-clean.sh first), and Swift should also be OK with 1.4.
>>> Ioan
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
