[Swift-user] debug log not being produced
Michael Wilde
wilde at mcs.anl.gov
Sun Mar 30 07:50:40 CDT 2008
Please ignore the last message (below).
I discovered another mistake of mine and need to correct things before I
can say whats happening.
- Mike
On 3/30/08 7:48 AM, Michael Wilde wrote:
> Its possible that using Java 1.4 is not the solution after all.
> The tests I ran using Java 1.4 were done using "ant dist" rather than
> the provider-deef.
> Now I've rebuilt swift and falkon, with Java 1.4, and I once again have
> the problem of no swift log being produced.
> Its possible that the problem is in fact that building swift with
> provider-deef is causing the no-log problem.
> I'll explore further.
> - Mike
> On 3/30/08 5:51 AM, Ben Clifford wrote:
>> what does 'which swift' output for you on that machine?
>> On Sun, 30 Mar 2008, Quan Tran Pham wrote:
>>> Hi,
>>> I tried to playing with different Java version for a while, but still
>>> cannot make Swift output the log on tp-login2 (Java 1.5 and Java 1.4).
>>> Should I rebuild ant as well? Everything else looks ok with Swift over
>>> Falkon.
>>> Thanks
>>> Quan
>>> On Sat, Mar 29, 2008 at 7:58 PM, Ioan Raicu <iraicu at cs.uchicago.edu>
>>> wrote:
>>>> Hi,
>>>> The fix for Mike on the BG/P was to switch from Java 1.5 to Java 1.4.
>>>> Not sure if this will also fix your problem, but its worth a try.
>>>> Falkon will compile just fine with 1.4 (don't forget to do
>>>> falkon-clean.sh first), and Swift should also be OK with 1.4.
>>>> Ioan
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
