[Swift-user] debug log not being produced
Ben Clifford
benc at hawaga.org.uk
Sun Mar 30 05:51:53 CDT 2008
what does 'which swift' output for you on that machine?
On Sun, 30 Mar 2008, Quan Tran Pham wrote:
> Hi,
> I tried to playing with different Java version for a while, but still
> cannot make Swift output the log on tp-login2 (Java 1.5 and Java 1.4).
> Should I rebuild ant as well? Everything else looks ok with Swift over
> Falkon.
> Thanks
> Quan
> On Sat, Mar 29, 2008 at 7:58 PM, Ioan Raicu <iraicu at cs.uchicago.edu> wrote:
> > Hi,
> > The fix for Mike on the BG/P was to switch from Java 1.5 to Java 1.4.
> > Not sure if this will also fix your problem, but its worth a try.
> > Falkon will compile just fine with 1.4 (don't forget to do
> > falkon-clean.sh first), and Swift should also be OK with 1.4.
> > Ioan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
