[Swift-user] debug log not being produced
Quan Tran Pham quanpt at cs.uchicago.edu
Sun Mar 30 00:17:24 CDT 2008
I tried to playing with different Java version for a while, but still
cannot make Swift output the log on tp-login2 (Java 1.5 and Java 1.4).
Should I rebuild ant as well? Everything else looks ok with Swift over
Falkon.
Thanks
Quan
On Sat, Mar 29, 2008 at 7:58 PM, Ioan Raicu <iraicu at cs.uchicago.edu> wrote:
> Hi,
>  The fix for Mike on the BG/P was to switch from Java 1.5 to Java 1.4.
>  Not sure if this will also fix your problem, but its worth a try.
>  Falkon will compile just fine with 1.4 (don't forget to do
>  falkon-clean.sh first), and Swift should also be OK with 1.4.
>  Ioan
More information about the Swift-user mailing list
