[Swift-user] RSL multi valued key
Mihael Hategan hategan at mcs.anl.gov
Sun Mar 30 00:32:21 CDT 2008
On Sun, 2008-03-30 at 00:12 +0000, Ben Clifford wrote:
> On Sat, 29 Mar 2008, Mihael Hategan wrote:
> > For the gt2 provider all GLOBUS::<name> attributes will make it into an
> > rsl argument named <name>.
> I know that. It gives a single string value.
> eg. something like this:
>  (condorsubmit= "(Requirements "Arch == ""WINNT5""")"
> What I'm after here is a multiple valued RSL key, something like the way
> the 'environment' RSL parameter is used:
>  (condorsubmit=(Requirements "Arch == ""WINNT5""")
I see. I don't think there is a way to do it nicely at this time.
> > Coincidentally (or not), skenny mentioned a similar thing yesterday. I'm
> > not yet sure if it worked for her or not.
> not coincidental. this is the same. I can do it from a GRAM rsl file (what
> I put in the original post) but I can't get that RSL generated from within
> Swift - I can only get a single string literal RSL value which doesn't
> work.
More information about the Swift-user mailing list
