[Swift-user] debug log not being produced
Ioan Raicu
iraicu at cs.uchicago.edu
Sat Mar 29 19:58:37 CDT 2008
The fix for Mike on the BG/P was to switch from Java 1.5 to Java 1.4.
Not sure if this will also fix your problem, but its worth a try.
Falkon will compile just fine with 1.4 (don't forget to do
falkon-clean.sh first), and Swift should also be OK with 1.4.
Ioan
Quan Tran Pham wrote:
> Hi,
> I am in the same situation, the log is not written out with my swift
> script that run fine before.
> The script was fine with Swift v0.3-dev r1684 (it did produce the log).
> My new swift + falkon: Swift svn swift-r1773 cog-r1953 (compiled
> follow http://dev.globus.org/wiki/Incubator/Falkon/Swift)
> I am running swift on Teraport tp-login2.ci
> JRE: Standard Edition (build 1.5.0_06-b05)
> Should I use some explicit flags for swift so that it will build the log?
> Thank you very much
> Quan Pham
> On Sat, Mar 29, 2008 at 9:39 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>> sorry, i didnt say clearly whats going on here:
>> with a clean 1773 build, running first.swift (hello world), on
>> terminable I get the log file fine, and on the bgp i get no log file.
>> I will test on the bgp with the alternative Java 1.4 release in /usr/bin
>> when I get a chance.
>> - mike
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
More information about the Swift-user
