[Swift-user] debug log not being produced
Quan Tran Pham
quanpt at cs.uchicago.edu
Sat Mar 29 19:57:35 CDT 2008
I am in the same situation, the log is not written out with my swift
script that run fine before.
The script was fine with Swift v0.3-dev r1684 (it did produce the log).
My new swift + falkon: Swift svn swift-r1773 cog-r1953 (compiled
follow http://dev.globus.org/wiki/Incubator/Falkon/Swift)
I am running swift on Teraport tp-login2.ci
JRE: Standard Edition (build 1.5.0_06-b05)
Should I use some explicit flags for swift so that it will build the log?
Thank you very much
Quan Pham
On Sat, Mar 29, 2008 at 9:39 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> sorry, i didnt say clearly whats going on here:
> with a clean 1773 build, running first.swift (hello world), on
> terminable I get the log file fine, and on the bgp i get no log file.
> I will test on the bgp with the alternative Java 1.4 release in /usr/bin
> when I get a chance.
> - mike
More information about the Swift-user
