[Swift-user] readdata or csv_mapper problem
Zhengxiong Hou
zhengxiongh at uchicago.edu
Mon Jul 14 15:08:25 CDT 2008
Hi Mike,
It works now for Swift 0.4. Actually, I modified it in
Swift 0.3 to use "space", but it seemed that the problem was
still there. I was puzzled.
Anyway, it can works now!
Thanks much!
Zhengxiong
---- Original message ----
>Date: Mon, 14 Jul 2008 14:43:16 -0500
>From: Michael Wilde <wilde at mcs.anl.gov>
>Subject: Re: [Swift-user] readdata or csv_mapper problem
>To: Zhengxiong Hou <zhengxiongh at uchicago.edu>
>Cc: swift-user at ci.uchicago.edu
>I think the readdata problem is that you need whitespace
between the var
>names in line 1. The Users Guide says:
>"For structs of scalars, the file should contain two rows.
The first row
>should be structure member names separated by whitespace.
The second row
>should be the corresponding values for each structure
member, separated
>by whitespace, in the same order as the header row."
More information about the Swift-user
