[Swift-user] readdata or csv_mapper problem
Michael Wilde
wilde at mcs.anl.gov
Mon Jul 14 14:43:16 CDT 2008
I think the readdata problem is that you need whitespace between the var
names in line 1. The Users Guide says:
"For structs of scalars, the file should contain two rows. The first row
should be structure member names separated by whitespace. The second row
should be the corresponding values for each structure member, separated
by whitespace, in the same order as the header row."
On 7/14/08 2:34 PM, Zhengxiong Hou wrote:
> Hello,
> When I try to run many dock jobs on the osg grid sites,
> there are problems for using readdata or csv_mapper. Please
> help to solve it. Here is the experiment at localhost:
> The swift code is as follows:
> [houzx at communicado dock]$ cat grid-many-dock6-string.swift
> type file;
> (file t) dockcompute (string ligandsfile, string targetlist)
> app {
> rundock ligandsfile targetlist stdout=@filename(t);
> type params {
> string ligandsfile;
> string targetlist;
> #params pset[] <csv_mapper;file="paramslist.txt">;
> doall(params pset[])
> foreach params,i in pset {
> #string mol2file <single_file_mapper; file=pset
> [i].ligandsfile>;
> #string target <single_file_mapper; file=pset
> [i].targetlist>;
> file sout <single_file_mapper; file=@strcat
> ("/home/houzx/dock-run/databases/results/",pset
> [i].targetlist,"-",i,"-stdout.txt")>;
> sout = dockcompute(pset[i].ligandsfile,pset
> [i].targetlist);
> params p[];
> p = readdata("paramslist.txt");
> doall(p);
> The content of "paramslist.txt" is as follows:
> [houzx at communicado dock]$ cat paramslist.txt
> ligandsfile,targetlist
> /home/houzx/dock-
> run/databases/KEGG_and_Drugs/D00180.mol2,1F9Y
> /home/houzx/dock-
> run/databases/KEGG_and_Drugs/D00181.mol2,1F9Y
> /home/houzx/dock-
> run/databases/KEGG_and_Drugs/D00182.mol2,1F9Y
> (1) Use this "readdata" code, and the log file is in the
> attachment "grid-many-dock6-string-20080714-readdata.log".
> [houzx at communicado dock]$ swift grid-many-dock6-string.swift
> Swift v0.4 swift-r1718 cog-r1934
> RunID: 20080714-1405-letz6tcb
> Progress:
> Execution failed:
> File header does not match type. Expected the
> following header items (in no particular order):
> [ligandsfile, targetlist]. Instead, the header was (again,
> in no particular order): [ligandsfile,targetlist]
> (2) Use csv_mapper, and the log file is in the attachment
> "grid-many-dock6-string-20080714-1417-csv.log"
> RunID: 20080714-1417-pmo8hsjf
> Progress:
> rundock started
> rundock started
> rundock started
> rundock completed
> rundock completed
> rundock completed
> Final status: Finished:3
> type file;
> app {
> type params {
> string ligandsfile;
> string targetlist;
> [i].targetlist);
> But, in the "/home/houzx/dock-run/databases/results/", the
> created files are: null-0-stdout.txt, null-1-stdout.txt,null-
> 2-stdout.txt.
> It means that "pset[i].targetlist" is set to be "null", not
> the data "1F9Y" from paramslist.txt!
> If I use "Swift v0.3", the created files are:true-0-
> stdout.txt,true-1-stdout.txt, true-2-stdout.txt.
> Thanks!
> B.R.
> zhengxiong
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
