[Swift-user] readdata or csv_mapper problem
    Zhengxiong Hou
    zhengxiongh at uchicago.edu
    Mon Jul 14 14:34:15 CDT 2008
Hello,
  When I try to run many dock jobs on the osg grid sites,
there are problems for using readdata or csv_mapper. Please
help to solve it. Here is the experiment at localhost:
  The swift code is as follows:
[houzx at communicado dock]$ cat grid-many-dock6-string.swift
type file;
(file t) dockcompute (string ligandsfile, string targetlist)
  app {
    rundock ligandsfile targetlist stdout=@filename(t);
type params {
      string  ligandsfile;
      string  targetlist;
#params pset[] <csv_mapper;file="paramslist.txt">;
doall(params pset[])
  foreach params,i in pset {
  #string mol2file <single_file_mapper; file=pset
[i].ligandsfile>;
  #string target <single_file_mapper; file=pset
[i].targetlist>;
  file sout <single_file_mapper; file=@strcat
("/home/houzx/dock-run/databases/results/",pset
[i].targetlist,"-",i,"-stdout.txt")>;
  sout =  dockcompute(pset[i].ligandsfile,pset
[i].targetlist);
params p[];
p = readdata("paramslist.txt");
doall(p);
The content of "paramslist.txt" is as follows:
[houzx at communicado dock]$ cat paramslist.txt
ligandsfile,targetlist
/home/houzx/dock-
run/databases/KEGG_and_Drugs/D00180.mol2,1F9Y
/home/houzx/dock-
run/databases/KEGG_and_Drugs/D00181.mol2,1F9Y
/home/houzx/dock-
run/databases/KEGG_and_Drugs/D00182.mol2,1F9Y
(1) Use this "readdata" code, and the log file is in the
attachment "grid-many-dock6-string-20080714-readdata.log".
[houzx at communicado dock]$ swift grid-many-dock6-string.swift
Swift v0.4 swift-r1718 cog-r1934
RunID: 20080714-1405-letz6tcb
Progress:
Execution failed:
        File header does not match type. Expected the
following header items (in no particular order):
[ligandsfile, targetlist]. Instead, the header was (again,
in no particular order): [ligandsfile,targetlist]
(2) Use csv_mapper, and the log file is in the attachment
"grid-many-dock6-string-20080714-1417-csv.log"
RunID: 20080714-1417-pmo8hsjf
Progress:
rundock started
rundock started
rundock started
rundock completed
rundock completed
rundock completed
Final status:  Finished:3
type file;
  app {
type params {
      string  ligandsfile;
      string  targetlist;
[i].targetlist);
 But, in the "/home/houzx/dock-run/databases/results/", the
created files are: null-0-stdout.txt, null-1-stdout.txt,null-
2-stdout.txt.
 It means that "pset[i].targetlist" is set to be "null", not
the data "1F9Y" from paramslist.txt!
 If I use "Swift v0.3", the created files are:true-0-
stdout.txt,true-1-stdout.txt, true-2-stdout.txt.
Thanks!
B.R.
zhengxiong
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080714/9ac9a0bb/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080714/9ac9a0bb/attachment-0001.obj>
More information about the Swift-user
