[Swift-user] Help: Error in Swift: Exitcode file not found 5 queue polls after the job was reported done
Quan Tran Pham
quanpt at cs.uchicago.edu
Wed Jan 30 17:16:32 CST 2008
Mihael, this is my first try using PBS, and I got into that error. I use
swift version 0.3.
Is there any document about using swift with PBS, other than this
http://www.ci.uchicago.edu/swift/guides/userguide.php#providers ?
Thank you
Quan Pham
On Jan 30, 2008 3:10 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Ok. I'll try to test it. What version of swift? And do you get this on
> every job, or just occasionally?
> On Wed, 2008-01-30 at 15:00 -0600, Quan Tran Pham wrote:
> > I use PBS on teraport tp-login machine, I guess I should you the same
> > shared file system with everyone.
> > Quan Pham
> > On Jan 30, 2008 2:31 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > So this is specific to the local PBS provider. It may indicate
> > a problem
> > with the shared filesystem, but I'll need more details of the
> > environment you're trying this on.
> > Mihael
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080130/16367279/attachment.html>
More information about the Swift-user
