[Swift-user] Help: Error in Swift: Exitcode file not found 5 queue polls after the job was reported done
Mihael Hategan hategan at mcs.anl.gov
Wed Jan 30 19:07:33 CST 2008
On Wed, 2008-01-30 at 17:16 -0600, Quan Tran Pham wrote:
> Mihael, this is my first try using PBS, and I got into that error. I
> use swift version 0.3.
> Is there any document about using swift with PBS, other than this
> http://www.ci.uchicago.edu/swift/guides/userguide.php#providers ?
There's this thing I started cleaning up:
http://wiki.cogkit.org/index.php/V:Head/Java_CoG_Kit_Abstractions_Guide#Available_Providers
But not much more.
Btw, I don't think you're doing anything wrong. I'm leaning towards
believing that there is a bug in the provider and I'm trying to gather
information so that I can reproduce and fix it.
Mihael
> Thank you
> Quan Pham
> On Jan 30, 2008 3:10 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>         Ok. I'll try to test it. What version of swift? And do you get
>         this on
>         every job, or just occasionally?
>         On Wed, 2008-01-30 at 15:00 -0600, Quan Tran Pham wrote:
>         > I use PBS on teraport tp-login machine, I guess I should you
>         the same
>         > shared file system with everyone.
>         > Quan Pham
>         > On Jan 30, 2008 2:31 PM, Mihael Hategan
>         >         So this is specific to the local PBS provider. It
>         may indicate
>         >         a problem
>         >         with the shared filesystem, but I'll need more
>         details of the
>         >         environment you're trying this on.
>         >         Mihael
More information about the Swift-user mailing list
