[Swift-user] Help: Error in Swift: Exitcode file not found 5 queue polls after the job was reported done
Mihael Hategan hategan at mcs.anl.gov
Wed Jan 30 15:10:48 CST 2008
Ok. I'll try to test it. What version of swift? And do you get this on
every job, or just occasionally?
On Wed, 2008-01-30 at 15:00 -0600, Quan Tran Pham wrote:
> I use PBS on teraport tp-login machine, I guess I should you the same
> shared file system with everyone.
> Quan Pham
> On Jan 30, 2008 2:31 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>         So this is specific to the local PBS provider. It may indicate
>         a problem
>         with the shared filesystem, but I'll need more details of the
>         environment you're trying this on.
>         Mihael
More information about the Swift-user mailing list
