[Swift-user] Resending: I/O errors in swift script
Mihael Hategan
hategan at mcs.anl.gov
Thu Aug 30 09:22:18 CDT 2007
Ok. You have a bunch of errors, mainly of two types:
1. Missing output file (we should add a rule in error.properties to make
that verbose message a little more readable). This may be because the
application didn't run or because the filesystem is broken. Right now an
exit code file is produced by the wrapper only if the exit code of the
application is not 0. This does not allow telling between the
application having completed successfully or the filesystem being
broken. I believe that a stamp file should also be created by the
wrapper in order to distinguish between the two. The reason for the
stamp file instead of always having an exit code file is that it is more
efficient to check the existence of a file than to stage it out and look
at its contents.
2. Exit code != 0. Looks like some issues with R.
Mihael
On Thu, 2007-08-30 at 08:31 -0500, Michael Wilde wrote:
> Resending this after changing list to take larger attachments.
> Previous message seems to have gotten lost (I musta pressed the wrong
> button in the list manager?)
> I'm progressing on the angle runs. Previous errors were due to problems
> with svn update, and then apparently needing ant clean and distclean.
> Now I'm executing but getting I/O errors. Ive attached all the logs and
> output from this run.
> My result files are coming back zero-length and Im seeing I/O errors in
> the logs (eg, in swift.out):
> Task(type=2, identity=urn:0-0-6-0-2-1188429807124) setting status to
> SubmittedTask(type=2, identity=urn:0-0-6-0-1-1188429807121) setting
> status to Active
> Task(type=2, identity=urn:0-0-6-0-2-1188429807124) setting status to Active
> Failed Exception in getFile
> My suspcion is that the app is failing and not proucing an expected
> output file. Perhaps theres a clean error in the log that says this but
> I havent found it yet. I think I saw error #500's from gridftp in the log.
> While I debug further, if anyone sees a different or obvious cause, I'd
> appreciate your eyeballs on it.
> Thanks,
> Mike
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
