[Swift-user] Resending: I/O errors in swift script
Michael Wilde
wilde at mcs.anl.gov
Thu Aug 30 08:31:37 CDT 2007
Resending this after changing list to take larger attachments.
Previous message seems to have gotten lost (I musta pressed the wrong
button in the list manager?)
I'm progressing on the angle runs. Previous errors were due to problems
with svn update, and then apparently needing ant clean and distclean.
Now I'm executing but getting I/O errors. Ive attached all the logs and
output from this run.
My result files are coming back zero-length and Im seeing I/O errors in
the logs (eg, in swift.out):
Task(type=2, identity=urn:0-0-6-0-2-1188429807124) setting status to
SubmittedTask(type=2, identity=urn:0-0-6-0-1-1188429807121) setting
status to Active
Task(type=2, identity=urn:0-0-6-0-2-1188429807124) setting status to Active
Failed Exception in getFile
My suspcion is that the app is failing and not proucing an expected
output file. Perhaps theres a clean error in the log that says this but
I havent found it yet. I think I saw error #500's from gridftp in the log.
While I debug further, if anyone sees a different or obvious cause, I'd
appreciate your eyeballs on it.
Mike
Type: application/x-tar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20070830/69ac2706/attachment.tar>
More information about the Swift-user
