[Swift-user] I/O errors in swift script
Michael Wilde wilde at mcs.anl.gov
Wed Aug 29 23:57:07 CDT 2007
I'm progressing on the angle runs. Previous errors were due to problems
with svn update, and then apparently needing ant clean and distclean.
Now I'm executing but getting I/O errors.  Ive attached all the logs and
output from this run.
My result files are coming back zero-length and Im seeing I/O errors in
the logs (eg, in swift.out):
Task(type=2, identity=urn:0-0-6-0-2-1188429807124) setting status to
SubmittedTask(type=2, identity=urn:0-0-6-0-1-1188429807121) setting
status to Active
Task(type=2, identity=urn:0-0-6-0-2-1188429807124) setting status to Active
Failed Exception in getFile
My suspcion is that the app is failing and not proucing an expected
output file.  Perhaps theres a clean error in the log that says this but
I havent found it yet.  I think I saw error #500's from gridftp in the log.
While I debug further, if anyone sees a different or obvious cause, I'd
appreciate your eyeballs on it.
Mike
Type: application/x-tar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20070829/9e7793fa/attachment.tar>
More information about the Swift-user mailing list
