[Swift-user] Re: Swift script throws exception in mapping
Michael Wilde wilde at mcs.anl.gov
Thu Aug 30 07:55:35 CDT 2007
This was solved. Apparently a svn update done within the cog directory
doesnt extend into the cog/modules/vdsk directory. Thats surprising, and
it dont know if its normal SVN behavior or some mis-config of mine.
Also, once I had done the vdsk update, an additional ant clean and ant
distclean was needed before the dist worked.
- Mike
Ben Clifford wrote:
> What SVN version is that? (type svn info into your root build directory)
> On Wed, 29 Aug 2007, Michael Wilde wrote:
>> Also: this was run on tg-viz-login1 from the directory ~wilde/angle/data
>> using awf1.swift and the swift dist in ~wilde/swift1730/vdsk-0.2-dev
>> - Mike
>>> The swift script:
>>> type pcapfile;
>>> type angleout;
>>> type anglecenter;
>>> (angleout ofile, anglecenter cfile) angle4 (pcapfile ifile)
>>>   app { angle4 @ifile @ofile @cfile; }
>>> pcapfile pcapfiles[]<filesys_mapper; prefix="pc", suffix=".pcap">;
>>> foreach pf in pcapfiles {
>>>   angleout of;
>>>   anglecenter cf;
>>>   (of,cf) = angle4(pf);
>>> throws the error below using trunk, 1730, updated around noon today:
>>> awf2.swift: source file is new. Recompiling.
>>> Using sites file: /home/wilde/swift1730/vdsk-0.2-dev/bin/../etc/sites.xml
>>> Using tc.data: /home/wilde/swift1730/vdsk-0.2-dev/bin/../etc/tc.data
>>> Swift v0.2-dev
>>> RunID: amf8l37tq0rh1
>>> java.lang.ClassCastException: org.griphyn.vdl.mapping.RootDataNode
>>>         vdl:new @ awf2.kml, line: 47
>>> Caused by: java.lang.ClassCastException:
>>>         at
>>> org.griphyn.vdl.mapping.RootArrayDataNode.init(RootArrayDataNode.java:22)
>>>         at org.griphyn.vdl.karajan.lib.New.function(New.java:88)
>>> The source, data and out/log files are attached.
>>> This code seemed to work circa 8/1 with 0.2 (or with a patch that Ben made
>>> to 0.2 around that date).
>>> I will continue to fiddle with it and try simpler code using 1730 but I'd
>>> appreciate it Ben and/or Mihael if you could investigate.
>>> Thanks,
>>> - Mike
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
