[Swift-user] Re: Swift script throws exception in mapping
Ben Clifford
benc at hawaga.org.uk
Thu Aug 30 07:30:40 CDT 2007
What SVN version is that? (type svn info into your root build directory)
On Wed, 29 Aug 2007, Michael Wilde wrote:
> Also: this was run on tg-viz-login1 from the directory ~wilde/angle/data
> using awf1.swift and the swift dist in ~wilde/swift1730/vdsk-0.2-dev
> - Mike
> > The swift script:
> > type pcapfile;
> > type angleout;
> > type anglecenter;
> > (angleout ofile, anglecenter cfile) angle4 (pcapfile ifile)
> > app { angle4 @ifile @ofile @cfile; }
> > pcapfile pcapfiles[]<filesys_mapper; prefix="pc", suffix=".pcap">;
> > foreach pf in pcapfiles {
> > angleout of;
> > anglecenter cf;
> > (of,cf) = angle4(pf);
> > throws the error below using trunk, 1730, updated around noon today:
> > awf2.swift: source file is new. Recompiling.
> > Using sites file: /home/wilde/swift1730/vdsk-0.2-dev/bin/../etc/sites.xml
> > Using tc.data: /home/wilde/swift1730/vdsk-0.2-dev/bin/../etc/tc.data
> > Swift v0.2-dev
> > RunID: amf8l37tq0rh1
> > java.lang.ClassCastException: org.griphyn.vdl.mapping.RootDataNode
> > vdl:new @ awf2.kml, line: 47
> > Caused by: java.lang.ClassCastException:
> > at
> > org.griphyn.vdl.mapping.RootArrayDataNode.init(RootArrayDataNode.java:22)
> > at org.griphyn.vdl.karajan.lib.New.function(New.java:88)
> > The source, data and out/log files are attached.
> > This code seemed to work circa 8/1 with 0.2 (or with a patch that Ben made
> > to 0.2 around that date).
> > I will continue to fiddle with it and try simpler code using 1730 but I'd
> > appreciate it Ben and/or Mihael if you could investigate.
> > Thanks,
> > - Mike
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
