[Swift-user] Re: Swift script throws exception in mapping
Ben Clifford benc at hawaga.org.uk
Thu Aug 30 07:59:33 CDT 2007
On Thu, 30 Aug 2007, Michael Wilde wrote:
> This was solved. Apparently a svn update done within the cog directory doesnt
> extend into the cog/modules/vdsk directory. Thats surprising, and it dont know
> if its normal SVN behavior or some mis-config of mine.
SVN doesn't recurse across checkouts.
the vdsk directory is a separate checkout that gets grafted into the
cog/modules/ directory. likewise for provider-deef.
this is a fairly unconventional way to build things.
> Also, once I had done the vdsk update, an additional ant clean and ant
> distclean was needed before the dist worked.
yes. that's pretty standard behaviour.
More information about the Swift-user mailing list
