[Swift-devel] Mailing lists, documentation update, etc.
Yadu Babuji yadunand at uchicago.edu
Tue Jul 28 19:35:31 CDT 2015
I couldn't meet with Stephen today. I'll send him mail asking for info on what he had to do to make a clean transition.
-Yadu
Sent via the Samsung Galaxy S® 6 edge, an AT&T 4G LTE smartphone
-------- Original message --------
Date: 07/28/2015 7:24 PM (GMT-06:00)
To: Matthew Shaxted <mattshax at gmail.com>
Cc: swift-devel at ci.uchicago.edu
Subject: Re: [Swift-devel] Mailing lists, documentation update, etc.
I see that Julia-Users is doing the same:
  https://groups.google.com/forum/#!forum/julia-users
Yadu mentioned that Globus has also moved to Google Groups, and was going to ask Stephen how they did the move.
I see that a simple wget -r will copy the mail archives, so we can likely preserve a static version of our archives, and then convert to Groups.
It only took a few mins to move the files, and they seem to be in a nicely relative format.  I had to manually view source on the swift-user base url and save as index.hml, and for some reason the current month (July) is not working, but the rest seems to work:
http://www.mcs.anl.gov/~wilde/swiftlists/swift-user/lists.ci.uchicago.edu/pipermail/swift-user/
So this might be a reasonable solution.
- Mike
On 7/28/15 6:47 PM, Matthew Shaxted wrote:
Google Groups seems to be a popular forum / list discussion solution.
An open source mapping platform called Cesium uses it with much success:
https://groups.google.com/forum/#!forum/cesium-dev<https://groups.google.com/forum/#%21forum/cesium-dev>
On Tue, Jul 28, 2015 at 5:25 AM, Michael Wilde <wilde at anl.gov<mailto:wilde at anl.gov>> wrote:
Dear All,
We need to handle this in the next 2 days to avoid outages on the Swift lists.
Has anyone already taken some actions for this, or has there already been a discussion or decision on how to handle this?
Whats the most accessible and open-source-friendly way to maintain list discussions?  We might need an interim solution, or we can use this as an opportunity to improve our communication channels and unify Swift K & T communications.
Craig's latest reminder on the CI mailing list close-out is at the end of this message.
- Mike
On 6/30/15 1:53 AM, Mihael Hategan wrote:
On Mon, 2015-06-29 at 23:16 -0500, Michael Wilde wrote:
This may be a good time to make the lists appear to be hosted at
swift-lang.org<http://swift-lang.org>.
An even better idea.
It would also be good to move the list archives to that domain. We
should see if that is possible, an dhow forwarding would work.
Yeah, I don't get how this works, but from Ian's quote of what Craig
says, the implementation and the interface seem to be different things.
So we should probably talk to Craig.
Mihael
-------- Forwarded Message --------
Subject:        REMINDER:Swift-devel mailing list to be retired July 31, 2015
Date:   Mon, 27 Jul 2015 09:09:39 -0500
From:   Craig Stacey <stace at mcs.anl.gov><mailto:stace at mcs.anl.gov>
Reply-To:       support at ci.uchicago.edu<mailto:support at ci.uchicago.edu>
To:     Swift-devel-owner at ci.uchicago.edu<mailto:Swift-devel-owner at ci.uchicago.edu>
As previously announced, the CI mailing list server will soon be retired.
You're receiving this message as a list owner of a list housed at
lists.ci.uchicago.edu<http://lists.ci.uchicago.edu>. Specifically, the following list:
Swift-devel at ci.uchicago.edu<mailto:Swift-devel at ci.uchicago.edu>, Last post at Sat Jul 25 09:12:44 2015.
https://lists.ci.uchicago.edu/mailman/listinfo/Swift-devel
(Note the above link also contains a link to any archives of the list as well.)
If you do nothing, the list will stop working at end of July. Any archives that
exist will disappear when the server is retired at that point.  Mail sent to
Swift-devel at ci.uchicago.edu<mailto:Swift-devel at ci.uchicago.edu> and Swift-devel at lists.ci.uchicago.edu<mailto:Swift-devel at lists.ci.uchicago.edu> will bounce,
and the sender will receive a notice that the address is no longer valid.
If you want to retain and move the list, your best option is to create a new
list on the service of your choice (for example, ITS provides mailing lists at
https://itservices.uchicago.edu/services/mailing-lists).  We don't have a way
to automate this process of moving from one service to another, unfortunately.
However, if you'd like a raw text dump of your existing configuration and
membership, we can provide that, simply let us know.  Otherwise, the web UI to
see your existing configuration and membership can be found at
https://lists.ci.uchicago.edu/mailman/admin/Swift-devel.  If you've forgotten the
password for your list, please let us know and we'll reset it.
Once you've got your new list configured and ready, if you'd like we can point
the existing listname Swift-devel at ci.uchicago.edu<mailto:Swift-devel at ci.uchicago.edu> to that new address.  Or you
can simply switch to using the new address, whatever that may be.
If you want the archives of your old CI list, let us know.  We can provide the
raw archives (including static HTML files) for you to use as you wish.  We do
not have a method of transferring the archives to whatever list provider you
choose to use for your new list, however.
Thanks, and sorry for the inconvenience.
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150729/355fd0d3/attachment.html>
