[Swift-devel] Mailing lists, documentation update, etc.
Michael Wilde wilde at anl.gov
Tue Jul 28 19:23:54 CDT 2015
I see that Julia-Users is doing the same:
   https://groups.google.com/forum/#!forum/julia-users
Yadu mentioned that Globus has also moved to Google Groups, and was
going to ask Stephen how they did the move.
I see that a simple wget -r will copy the mail archives, so we can
likely preserve a static version of our archives, and then convert to
Groups.
It only took a few mins to move the files, and they seem to be in a
nicely relative format.  I had to manually view source on the swift-user
base url and save as index.hml, and for some reason the current month
(July) is not working, but the rest seems to work:
http://www.mcs.anl.gov/~wilde/swiftlists/swift-user/lists.ci.uchicago.edu/pipermail/swift-user/
So this might be a reasonable solution.
- Mike
On 7/28/15 6:47 PM, Matthew Shaxted wrote:
> Google Groups seems to be a popular forum / list discussion solution.
> An open source mapping platform called Cesium uses it with much success:
> https://groups.google.com/forum/#!forum/cesium-dev
> <https://groups.google.com/forum/#%21forum/cesium-dev>
> On Tue, Jul 28, 2015 at 5:25 AM, Michael Wilde <wilde at anl.gov
> <mailto:wilde at anl.gov>> wrote:
>     Dear All,
>     We need to handle this in the next 2 days to avoid outages on the
>     Swift lists.
>     Has anyone already taken some actions for this, or has there
>     already been a discussion or decision on how to handle this?
>     Whats the most accessible and open-source-friendly way to maintain
>     list discussions?  We might need an interim solution, or we can
>     use this as an opportunity to improve our communication channels
>     and unify Swift K & T communications.
>     Craig's latest reminder on the CI mailing list close-out is at the
>     end of this message.
>     Thanks,
>     - Mike
>     On 6/30/15 1:53 AM, Mihael Hategan wrote:
>>     On Mon, 2015-06-29 at 23:16 -0500, Michael Wilde wrote:
>>>     This may be a good time to make the lists appear to be hosted at
>>>     swift-lang.org  <http://swift-lang.org>.
>>     An even better idea.
>>>     It would also be good to move the list archives to that domain. We
>>>     should see if that is possible, an dhow forwarding would work.
>>     Yeah, I don't get how this works, but from Ian's quote of what Craig
>>     says, the implementation and the interface seem to be different things.
>>     So we should probably talk to Craig.
>>     Mihael
>     -------- Forwarded Message --------
>     Subject: 	REMINDER:Swift-devel mailing list to be retired July 31,
>     2015
>     Date: 	Mon, 27 Jul 2015 09:09:39 -0500
>     From: 	Craig Stacey <stace at mcs.anl.gov> <mailto:stace at mcs.anl.gov>
>     Reply-To: 	support at ci.uchicago.edu <mailto:support at ci.uchicago.edu>
>     To: 	Swift-devel-owner at ci.uchicago.edu
>     <mailto:Swift-devel-owner at ci.uchicago.edu>
>     As previously announced, the CI mailing list server will soon be retired.
>     You're receiving this message as a list owner of a list housed at
>     lists.ci.uchicago.edu  <http://lists.ci.uchicago.edu>. Specifically, the following list:
>     Swift-devel at ci.uchicago.edu  <mailto:Swift-devel at ci.uchicago.edu>, Last post at Sat Jul 25 09:12:44 2015.
>     https://lists.ci.uchicago.edu/mailman/listinfo/Swift-devel
>     (Note the above link also contains a link to any archives of the list as well.)
>     If you do nothing, the list will stop working at end of July. Any archives that
>     exist will disappear when the server is retired at that point.  Mail sent to
>     Swift-devel at ci.uchicago.edu  <mailto:Swift-devel at ci.uchicago.edu>  andSwift-devel at lists.ci.uchicago.edu  <mailto:Swift-devel at lists.ci.uchicago.edu>  will bounce,
>     and the sender will receive a notice that the address is no longer valid.
>     If you want to retain and move the list, your best option is to create a new
>     list on the service of your choice (for example, ITS provides mailing lists at
>     https://itservices.uchicago.edu/services/mailing-lists).  We don't have a way
>     to automate this process of moving from one service to another, unfortunately.
>     However, if you'd like a raw text dump of your existing configuration and
>     membership, we can provide that, simply let us know.  Otherwise, the web UI to
>     see your existing configuration and membership can be found at
>     https://lists.ci.uchicago.edu/mailman/admin/Swift-devel.  If you've forgotten the
>     password for your list, please let us know and we'll reset it.
>     Once you've got your new list configured and ready, if you'd like we can point
>     the existing listnameSwift-devel at ci.uchicago.edu  <mailto:Swift-devel at ci.uchicago.edu>  to that new address.  Or you
>     can simply switch to using the new address, whatever that may be.
>     If you want the archives of your old CI list, let us know.  We can provide the
>     raw archives (including static HTML files) for you to use as you wish.  We do
>     not have a method of transferring the archives to whatever list provider you
>     choose to use for your new list, however.
>     Thanks, and sorry for the inconvenience.
>     Michael Wilde
>     Mathematics and Computer Science          Computation Institute
>     Argonne National Laboratory               The University of Chicago
>     _______________________________________________
>     https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150728/ef647a65/attachment.html>
