[Swift-devel] Mailing lists, documentation update, etc.
Matthew Shaxted
mattshax at gmail.com
Tue Jul 28 18:47:46 CDT 2015
Google Groups seems to be a popular forum / list discussion solution.
An open source mapping platform called Cesium uses it with much success:
https://groups.google.com/forum/#!forum/cesium-dev
On Tue, Jul 28, 2015 at 5:25 AM, Michael Wilde <wilde at anl.gov> wrote:
> Dear All,
> We need to handle this in the next 2 days to avoid outages on the Swift
> lists.
> Has anyone already taken some actions for this, or has there already been
> a discussion or decision on how to handle this?
> Whats the most accessible and open-source-friendly way to maintain list
> discussions? We might need an interim solution, or we can use this as an
> opportunity to improve our communication channels and unify Swift K & T
> communications.
> Craig's latest reminder on the CI mailing list close-out is at the end of
> this message.
> Thanks,
> - Mike
> On 6/30/15 1:53 AM, Mihael Hategan wrote:
> On Mon, 2015-06-29 at 23:16 -0500, Michael Wilde wrote:
> This may be a good time to make the lists appear to be hosted at swift-lang.org.
> An even better idea.
> It would also be good to move the list archives to that domain. We
> should see if that is possible, an dhow forwarding would work.
> Yeah, I don't get how this works, but from Ian's quote of what Craig
> says, the implementation and the interface seem to be different things.
> So we should probably talk to Craig.
> Mihael
> -------- Forwarded Message -------- Subject: REMINDER:Swift-devel
> mailing list to be retired July 31, 2015 Date: Mon, 27 Jul 2015 09:09:39
> -0500 From: Craig Stacey <stace at mcs.anl.gov> <stace at mcs.anl.gov> Reply-To:
> support at ci.uchicago.edu To: Swift-devel-owner at ci.uchicago.edu
> As previously announced, the CI mailing list server will soon be retired.
> You're receiving this message as a list owner of a list housed atlists.ci.uchicago.edu. Specifically, the following list:
> Swift-devel at ci.uchicago.edu, Last post at Sat Jul 25 09:12:44 2015.https://lists.ci.uchicago.edu/mailman/listinfo/Swift-devel
> (Note the above link also contains a link to any archives of the list as well.)
> If you do nothing, the list will stop working at end of July. Any archives that
> exist will disappear when the server is retired at that point. Mail sent toSwift-devel at ci.uchicago.edu and Swift-devel at lists.ci.uchicago.edu will bounce,
> and the sender will receive a notice that the address is no longer valid.
> If you want to retain and move the list, your best option is to create a new
> list on the service of your choice (for example, ITS provides mailing lists athttps://itservices.uchicago.edu/services/mailing-lists). We don't have a way
> to automate this process of moving from one service to another, unfortunately.
> However, if you'd like a raw text dump of your existing configuration and
> membership, we can provide that, simply let us know. Otherwise, the web UI to
> see your existing configuration and membership can be found athttps://lists.ci.uchicago.edu/mailman/admin/Swift-devel. If you've forgotten the
> password for your list, please let us know and we'll reset it.
> Once you've got your new list configured and ready, if you'd like we can point
> the existing listname Swift-devel at ci.uchicago.edu to that new address. Or you
> can simply switch to using the new address, whatever that may be.
> If you want the archives of your old CI list, let us know. We can provide the
> raw archives (including static HTML files) for you to use as you wish. We do
> not have a method of transferring the archives to whatever list provider you
> choose to use for your new list, however.
> Thanks, and sorry for the inconvenience.
> Michael Wilde
> Mathematics and Computer Science Computation Institute
> Argonne National Laboratory The University of Chicago
> Swift-devel mailing list
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150728/38054385/attachment.html>
