[Swift-devel] Standard Library Proposal/Discussion Page
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Tue Jan 20 20:36:46 CST 2015
How should we discuss things?  Is it best to flag potential issues on the
wiki, or should I mention it in here?
- Tim
On Tue, Jan 20, 2015 at 6:56 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Hi,
> I made a wiki page on github where we could discuss the standard
> library: https://github.com/swift-lang/swift-k/wiki/StandardLibrary
> It's a draft and there are some rough edges. In particular:
> - regular expression support: substitutions can be done either directly
> or with a combination between a function that returns capture groups and
> a formatting function that replaces certain tokens with elements of an
> array. One could overload the format() function to, in addition to
> standard formatting specs, also support something like %s[index]. Or
> have a separate formatting function that only deals with this specific
> problem. I'm not sure.
> - some of the array functions may be difficult to implement as
> specified, or there may be different functions that solve the problems
> better. In particular when joining arrays of arrays, there is some
> freedom in how to order the elements of the resulting array.
> - read and write: it may not be easy to implement a read that can return
> any type in T. There is some precedent in other languages that support
> serialization for this.
> Anyway, I added red exclamation marks and red question marks where
> things aren't quite clear.
> I'm assuming that most of us will agree on most of the things. However,
> if you have a wildly different proposal, it might be wise to create
> another page instead of editing this one.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150120/8723c85e/attachment.html>
