[Swift-devel] Standard Library Proposal/Discussion Page
Mihael Hategan
hategan at mcs.anl.gov
Tue Jan 20 20:56:00 CST 2015
I'm not sure. I think both.
Let's try this: we use the wiki to mark points of contention. It gives
us a quick overall view on the status. We discuss them through email and
remove marks on the wiki as we develop fixes/agreements.
I forgot to mention that there are going to have to be portions of the
library that are specific to either T or K because that's just how some
things have to be (e.g. file() in T). I don't think we should include
them in this document/discussion. In other words, let's focus on the
things for which there is no good reason to have different
specifications in T and K.
Mihael
On Tue, 2015-01-20 at 20:36 -0600, Tim Armstrong wrote:
> How should we discuss things? Is it best to flag potential issues on the
> wiki, or should I mention it in here?
> - Tim
> On Tue, Jan 20, 2015 at 6:56 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > Hi,
> > I made a wiki page on github where we could discuss the standard
> > library: https://github.com/swift-lang/swift-k/wiki/StandardLibrary
> > It's a draft and there are some rough edges. In particular:
> > - regular expression support: substitutions can be done either directly
> > or with a combination between a function that returns capture groups and
> > a formatting function that replaces certain tokens with elements of an
> > array. One could overload the format() function to, in addition to
> > standard formatting specs, also support something like %s[index]. Or
> > have a separate formatting function that only deals with this specific
> > problem. I'm not sure.
> > - some of the array functions may be difficult to implement as
> > specified, or there may be different functions that solve the problems
> > better. In particular when joining arrays of arrays, there is some
> > freedom in how to order the elements of the resulting array.
> > - read and write: it may not be easy to implement a read that can return
> > any type in T. There is some precedent in other languages that support
> > serialization for this.
> > Anyway, I added red exclamation marks and red question marks where
> > things aren't quite clear.
> > I'm assuming that most of us will agree on most of the things. However,
> > if you have a wildly different proposal, it might be wise to create
> > another page instead of editing this one.
> > Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
