[Swift-devel] Standard library
    Tim Armstrong
    tim.g.armstrong at gmail.com
    Sat Jan 10 22:57:49 CST 2015
I'm actually pretty indifferent :)  I switch between the two styles so much
anyway.
- Tim
On Sat, Jan 10, 2015 at 10:02 PM, Mihael Hategan <hategan at mcs.anl.gov>
wrote:
> On Sat, 2015-01-10 at 16:57 -0600, Tim Armstrong wrote:
> > I agree, I don't care about the naming convention for functions, so let's
> > just pick one and be consistent going forward (we can keep old names
> > around, at least forsome amount of time).
> Let's briefly discuss this and put it to a vote.
> I prefer camel case because it helps with tokenization in my head. In
> other words when I read a program, I would like a variable or function
> name to be a single entity visually. Underscores are very close to a
> blank, so it's easy to confuse the two on a quick visual scan and
> interpret, say function_name, as two separate tokens instead of one.
> Other than that, complex tokens themselves are probably easier to read
> with underscores: long_name_of_variable_that_holds_value vs
> longNameOfVariableThatHoldsValue.
> See http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.158.9499 and
> http://www.cs.kent.edu/~jmaletic/papers/ICPC2010-CamelCaseUnderScoreClouds.pdf
> for some relevant research. Unfortunately they focus not on program
> readability, but on identifier readability.
> Mihael
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150110/dd9ceae3/attachment.html>
