[Swift-devel] Naming convention discussion
    Mihael Hategan
    hategan at mcs.anl.gov
    Sat Jan 10 23:41:32 CST 2015
Just changing subject to reduce confusion.
On Sat, 2015-01-10 at 22:57 -0600, Tim Armstrong wrote:
> I'm actually pretty indifferent :)  I switch between the two styles so much
> anyway.
> - Tim
> On Sat, Jan 10, 2015 at 10:02 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> > On Sat, 2015-01-10 at 16:57 -0600, Tim Armstrong wrote:
> > > I agree, I don't care about the naming convention for functions, so let's
> > > just pick one and be consistent going forward (we can keep old names
> > > around, at least forsome amount of time).
> > Let's briefly discuss this and put it to a vote.
> > I prefer camel case because it helps with tokenization in my head. In
> > other words when I read a program, I would like a variable or function
> > name to be a single entity visually. Underscores are very close to a
> > blank, so it's easy to confuse the two on a quick visual scan and
> > interpret, say function_name, as two separate tokens instead of one.
> > Other than that, complex tokens themselves are probably easier to read
> > with underscores: long_name_of_variable_that_holds_value vs
> > longNameOfVariableThatHoldsValue.
> > See http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.158.9499 and
> > http://www.cs.kent.edu/~jmaletic/papers/ICPC2010-CamelCaseUnderScoreClouds.pdf
> > for some relevant research. Unfortunately they focus not on program
> > readability, but on identifier readability.
> > Mihael
