[Swift-devel] .swiftx and .kml files
    Yadu Nand
    yadudoc1729 at gmail.com
    Thu Mar 27 23:38:06 CDT 2014
We could make the kml and swiftx files dot files, or we could move them to
the run directory instead of deleting them.
On Thu, Mar 27, 2014 at 11:11 PM, David Kelly <davidkelly at uchicago.edu>wrote:
> I think the problem with keeping *.xml and *.swiftx is that it clutters up
> your working directory with files that the majority of Swift users will
> never (directly) use.
> Is it possible to make the xml and swiftx files hidden? You'd get any
> possible compilation benefits without them getting in the way.
> Otherwise I'd say it makes sense to have a property to control this:
> If script.debug.keep=false (default) and a run directory is created, move
> them to the run directory at the end of the run so they are available for
> debugging
> If script.debug.keep=false and no run directory is created, remove them
> If script.debug.keep=true, keep them untouched in the current working
> directory
> On Thu, Mar 27, 2014 at 10:25 PM, Mihael Hategan <hategan at mcs.anl.gov>wrote:
>> Hi,
>> The .swiftx and .kml files get deleted by bin/swift after a run. They
>> are maybe not very user friendly, but they are useful for debugging and
>> swift skips re-compiling things if they are already there. Python does
>> something similar.
>> So I would vote against having them deleted.
>> Mihael
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140327/76c3d79c/attachment.html>
