[Swift-devel] Swift on Google compute engine [Request for comments]
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jun 27 10:54:42 CDT 2014
Nice!
One suggestion is that we probably should encourage dropping the @ in
front of functions.
Mihael
On Fri, 2014-06-27 at 10:47 -0500, Yadu Nand Babuji wrote:
> Hi Everyone,
> Please try the Google Compute Engine setup and tutorial, I've linked below.
> This will require credit card information and will bill you
> approximately $0.065/Hr
> with the default config of 5 micro instances.
> Cloud setup online doc:
> https://github.com/yadudoc/swift-on-cloud/tree/master/compute-engine
> Git repo to clone:
> https://github.com/yadudoc/swift-on-cloud.git
> Once setup is done, do "connect headnode" and you can run the
> swift-cloud-tutorial
> under your $HOME/swift-on-cloud/swift-cloud-tutorial folder on the
> headnode instance.
> Feedback would be much appreciated.
> PS: Remember to shut-down instances using the "dissolve" command.
> Thanks!
> Yadu
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
