[Swift-devel] Swift on Google compute engine [Request for	comments]
    Yadu Nand Babuji
    yadunand at uchicago.edu
    Fri Jun 27 11:08:47 CDT 2014
Thanks!
I'm guessing that you are talking about the README in
swift-cloud-tutorial. I've corrected the doc, and the
code was already not using any @ prefix for functions.
-Yadu
On 06/27/2014 10:54 AM, Mihael Hategan wrote:
> Nice!
> One suggestion is that we probably should encourage dropping the @ in
> front of functions.
> Mihael
> On Fri, 2014-06-27 at 10:47 -0500, Yadu Nand Babuji wrote:
>> Hi Everyone,
>> Please try the Google Compute Engine setup and tutorial, I've linked below.
>> This will require credit card information and will bill you
>> approximately $0.065/Hr
>> with the default config of 5 micro instances.
>> Cloud setup online doc:
>> https://github.com/yadudoc/swift-on-cloud/tree/master/compute-engine
>> Git repo to clone:
>> https://github.com/yadudoc/swift-on-cloud.git
>> Once setup is done, do "connect headnode" and you can run the
>> under your $HOME/swift-on-cloud/swift-cloud-tutorial folder on the
>> headnode instance.
>> Feedback would be much appreciated.
>> PS: Remember to shut-down instances using the "dissolve" command.
>> Thanks!
>> Yadu
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
