[Swift-devel] Swift on Google compute engine [Request for comments]
    Yadu Nand Babuji
    yadunand at uchicago.edu
    Fri Jun 27 10:47:40 CDT 2014
Hi Everyone,
Please try the Google Compute Engine setup and tutorial, I've linked below.
This will require credit card information and will bill you
approximately $0.065/Hr
with the default config of 5 micro instances.
Cloud setup online doc:
https://github.com/yadudoc/swift-on-cloud/tree/master/compute-engine
Git repo to clone:
https://github.com/yadudoc/swift-on-cloud.git
Once setup is done, do "connect headnode" and you can run the
swift-cloud-tutorial
under your $HOME/swift-on-cloud/swift-cloud-tutorial folder on the
headnode instance.
Feedback would be much appreciated.
PS: Remember to shut-down instances using the "dissolve" command.
Thanks!
Yadu
