[Swift-devel] Issues to resolve for the 0.96 config mechanism
Mihael Hategan hategan at mcs.anl.gov
Thu Jul 24 18:38:15 CDT 2014
This should now be all committed to trunk. Except for SWIFT_CONF_PATH. I
noticed I forgot about it while replying to this email.
Mihael
On Wed, 2014-07-16 at 14:14 -0500, Michael Wilde wrote:
> On 7/16/14, 1:04 AM, Mihael Hategan wrote:
> > Hi,
> > I'll be in New York for the remainder of the week and returning Monday
> > (21st). I might sporadically work on this, but in all likelihood commits
> > will come after that. However, I wanted so sync on the latest spec:
> > * releaseConf=$SWIFT_HOME/etc/swift.conf
> > siteConf=$SWIFT_SITE_CONF (if $SWIFT_SITE_CONF defined)
> > userConf=$HOME/.swift/swift.conf (if present)
> > runConf=$PWD/swift.conf (if present)
> > -config
> ...and then specific command line options.  Should all conf options be
> allowed, exactly as in the conf file? Or just all "scalar" options?
> Should we move to a -D notation for specifying conf options on the
> command line, or leave as-is?
> > * The configs should be chained automatically.
> > * Documentation updated, in particular copying and updating the 0.95
> > section on the search path and documenting swift-convert-config and how
> > to migrate from pre-0.95 files. The tool should also be updated to
> > accept and convert 0.95 configs.
> > * -noReleaseConf, -noSiteConf, -noUserConf, -noRunConf command-line
> > flags to be added. Please comment on the equivalent properties and the
> > difficulty in implementing them. If you feel it's important, it might be
> > worth conquering those difficulties.
> Lets drop these. On re-consideration, they seem too complex.
> > * line numbers for properties in -listconfig and log.
> Good idea.
> > Things that might still merit some discussion:
> > * -listconfig <files|full> (this is a proposal to add a parameter to
> > -listconfig that specifies whether only a list of files or a list of
> > files and all options should be printed).
> sounds ok
> > * Also please comment on the -config file vs. -config file1:file2... and
> > the need for -reconfig. I can't quite tell whether these were meant to
> > be discussed or not, and if yes, where we are with that.
> How about the following alternative to the above:
> -config file replaces $PWD/swift.conf in the search path
> -configpath file:file:file replaces the full search path with the
> specified path
> SWIFT_CONF_PATH env var does the same thing as -configpath
> This seems simpler.  Either accept the default search path, or specify
> your own.
> There may be a few interactions between these that we would need to
> fully specify, but it seems like the right track.
> For now, Im happy with just "-config file". The other two could be done
> at a later time.
> > - another question is whether we want properties (in -listconfig and
> > log) to be printed as a flat set of dotted properties or grouped. In
> > other words:
> > site.one.workDirectory = ..
> > site.one.staging = ...
> > or
> > site.one {
> >    workDirectory = ...
> >    staging = ...
> The second is nicer; the first seems easier to code. Both are OK for now.
> - Mike
> > Mihael
