[Swift-devel] Issues to resolve for the 0.96 config mechanism
Michael Wilde wilde at anl.gov
Mon Jul 14 20:04:13 CDT 2014
On 7/14/14, 1:00 PM, Mihael Hategan wrote:
> The first question is whether ~/.swift/swift.conf and ./swift.conf
> should be explicitly in the search path, since SWIFT_SITE_CONF can do
> both:
> export SWIFT_SITE_CONF=~/.swift/swift.conf
> export SWIFT_SITE_CONF=./swift.conf
This variable was intended specifically for shared site definitions, to
be provided by the group that administers Swift on the site (eg, like
the RCC team), for use by all Swift users at the location.
If its value can only be a single filename, it can not serve this
site-wide role in addition to the two alternative roles you show above:
personal settings (~/.swift/swift.conf), and run-specific settings
(./swift.conf). This variable can only serve one of these three roles.
But I don't think that this is the first question.  The first question
is, should we have a search path for conf settings, and if so, what
should it be.
You indicated however that ~/.swift/swift.conf remains in use for
personal settings. That's good.
So the sole difference in property search path between 0.95 RC6 and
trunk is that trunk no longer reads a property file by a fixed name from
the current directory in which swift is run.
0.94 had:
swift installation
user
-config
command-line options
0.95 had:
swift installation
site-wide (new)
user
script (./) (new)
-config
command line
trunk has:
swift installation
site-wide
user
-config
command line
So the first point to discuss is in fact do we retain or remove the 0.95
notion that properties that apply to a specific script can be placed
alongside the script with no additional arguments on the swift command.
Because that is, from considerable experience, the way most users use
swift. Ive been creating a .cf file and specifying "-config cf" for many
many years. Its just a question of whether virtually every swift
invocation will continue to need to specify -config or not.
If the argument is that the user might mis-spell the name of the
./swift.conf file, and perform a run with differet properties than were
intended, I think thats a weak argument for removing this feature.  The
user could just as easily mis-spell ~/.swift/swift.conf. An emacs user
could mispell ~/.emacs or ~/.bashrc and the intended file would also be
silently ignored. But there's a strong precedent for implicitly assumed
config filenames in a variety of locations, and I think ./swift.conf
calls into that same category.
One option is to add a property that specifies whether a default
per-script config file is read.  This would be typically then specified
by the user (or the tutorial setup) in ~/.swift/swift.conf. E.g.:
   perScriptConfig: ./swift.conf
If we need to keep specifying -config, I can live with that.  I'm more
concerned that, in swift tutorials, simple things be simple. I like the
simplicity of saying "swift part06.swift".
- Mike
