[Swift-devel] trunk fails to build on Edison
Ketan Maheshwari
ketan at mcs.anl.gov
Thu Dec 18 10:55:52 CST 2014
Right ant was 1.7.0
Strangely, despite using ant from a newer version, it is still showing the
old one:
ketan at edison01:~/swift-k> ant -version
Apache Ant version 1.7.0 compiled on November 9 2012
ketan at edison01:~/swift-k> which ant
/global/homes/k/ketan/apache-ant-1.9.4/bin/ant
/global/homes/k/ketan/apache-ant-1.9.4/bin/ant -version
Any ideas?
On Thu, Dec 18, 2014 at 9:52 AM, Justin M Wozniak <wozniak at mcs.anl.gov>
wrote:
> Can you check that Ant version?
> http://stackoverflow.com/questions/6491796/fileset-doesnt-support-the-erroronmissingdir-attribute
> On 12/18/2014 09:27 AM, Ketan Maheshwari wrote:
> Hi,
> Swift from trunk is failing to build on Edison with the following errors:
> BUILD FAILED
> /global/u2/k/ketan/swift-devel/cog/modules/swift/build.xml:355: fileset
> doesn't support the "erroronmissingdir" attribute
> Total time: 0 seconds
> ketan at edison02:~/swift-devel/cog/modules/swift> ant dist
> Buildfile: build.xml
> generateVersion:
> antlr:
> [java] ANTLR Parser Generator Version 2.7.5 (20050128) 1989-2005
> jGuru.com
> [java] resources/swiftscript.g:1077: warning:nondeterminism upon
> [java] resources/swiftscript.g:1077: k==1:LBRACK
> k==2:ID,STRING_LITERAL,LBRACK,LPAREN,AT,PLUS,MINUS,STAR,NOT,INT_LITERAL,FLOAT_LITERAL,"true","false"
> [java] resources/swiftscript.g:1077: between alt 1 and exit
> branch of block
> compileSchema:
> [java] Time to build schema type system: 0.973 seconds
> [java] Time to generate code: 0.524 seconds
> [java] Time to compile code: 4.389 seconds
> [java] Compiled types to:
> /global/u2/k/ketan/swift-devel/cog/modules/swift/../../modules/swift/lib/vdldefinitions.jar
> compileParams:
> [echo] [swift] Compiling mapper params compiler
> [echo] [swift] Generating mapping parameter classes
> dist:
> BUILD FAILED
> /global/u2/k/ketan/swift-devel/cog/modules/swift/build.xml:73: The
> following error occurred while executing this line:
> /global/u2/k/ketan/swift-devel/cog/mbuild.xml:18: fileset doesn't support
> Total time: 8 seconds
> java is:
> /opt/java/jdk1.7.0_45/bin/java
> Any suggestions?
> Thanks,
> Ketan
> Swift-devel mailing listSwift-devel at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20141218/c5c6af06/attachment.html>
