[Swift-devel] trunk fails to build on Edison
Justin M Wozniak wozniak at mcs.anl.gov
Thu Dec 18 09:52:44 CST 2014
Can you check that Ant version?
http://stackoverflow.com/questions/6491796/fileset-doesnt-support-the-erroronmissingdir-attribute
On 12/18/2014 09:27 AM, Ketan Maheshwari wrote:
> Hi,
> Swift from trunk is failing to build on Edison with the following errors:
> BUILD FAILED
> /global/u2/k/ketan/swift-devel/cog/modules/swift/build.xml:355:
> fileset doesn't support the "erroronmissingdir" attribute
> Total time: 0 seconds
> ketan at edison02:~/swift-devel/cog/modules/swift> ant dist
> Buildfile: build.xml
> generateVersion:
> antlr:
>      [java] ANTLR Parser Generator   Version 2.7.5 (20050128)
> 1989-2005 jGuru.com
>      [java] resources/swiftscript.g:1077: warning:nondeterminism upon
>      [java] resources/swiftscript.g:1077:     k==1:LBRACK
> k==2:ID,STRING_LITERAL,LBRACK,LPAREN,AT,PLUS,MINUS,STAR,NOT,INT_LITERAL,FLOAT_LITERAL,"true","false"
>      [java] resources/swiftscript.g:1077:     between alt 1 and exit
> branch of block
> compileSchema:
>      [java] Time to build schema type system: 0.973 seconds
>      [java] Time to generate code: 0.524 seconds
>      [java] Time to compile code: 4.389 seconds
>      [java] Compiled types to:
> /global/u2/k/ketan/swift-devel/cog/modules/swift/../../modules/swift/lib/vdldefinitions.jar
> compileParams:
>      [echo] [swift] Compiling mapper params compiler
>      [echo] [swift] Generating mapping parameter classes
> dist:
> BUILD FAILED
> /global/u2/k/ketan/swift-devel/cog/modules/swift/build.xml:73: The
> following error occurred while executing this line:
> /global/u2/k/ketan/swift-devel/cog/mbuild.xml:18: fileset doesn't
> Total time: 8 seconds
> java is:
> /opt/java/jdk1.7.0_45/bin/java
> Any suggestions?
> Thanks,
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20141218/de4e3179/attachment.html>
