[Swift-devel] trunk fails to build on Edison
Justin M Wozniak wozniak at mcs.anl.gov
Thu Dec 18 11:04:48 CST 2014
Have you set ANT_HOME or JAVA_HOME?  Try unsetting them or setting them
to the correct locations.
On 12/18/2014 10:55 AM, Ketan Maheshwari wrote:
> Right ant was 1.7.0
> Strangely, despite using ant from a newer version, it is still showing
> the old one:
> ketan at edison01:~/swift-k> ant -version
> Apache Ant version 1.7.0 compiled on November 9 2012
> ketan at edison01:~/swift-k> which ant
> /global/homes/k/ketan/apache-ant-1.9.4/bin/ant
> /global/homes/k/ketan/apache-ant-1.9.4/bin/ant -version
> Any ideas?
> On Thu, Dec 18, 2014 at 9:52 AM, Justin M Wozniak <wozniak at mcs.anl.gov
> <mailto:wozniak at mcs.anl.gov>> wrote:
>     Can you check that Ant version?
>     http://stackoverflow.com/questions/6491796/fileset-doesnt-support-the-erroronmissingdir-attribute
>     On 12/18/2014 09:27 AM, Ketan Maheshwari wrote:
>>     Hi,
>>     Swift from trunk is failing to build on Edison with the following
>>     errors:
>>     BUILD FAILED
>>     /global/u2/k/ketan/swift-devel/cog/modules/swift/build.xml:355:
>>     fileset doesn't support the "erroronmissingdir" attribute
>>     Total time: 0 seconds
>>     ketan at edison02:~/swift-devel/cog/modules/swift> ant dist
>>     Buildfile: build.xml
>>     generateVersion:
>>     antlr:
>>          [java] ANTLR Parser Generator Version 2.7.5 (20050128)
>>     1989-2005 jGuru.com
>>          [java] resources/swiftscript.g:1077: warning:nondeterminism upon
>>          [java] resources/swiftscript.g:1077:   k==1:LBRACK
>>     k==2:ID,STRING_LITERAL,LBRACK,LPAREN,AT,PLUS,MINUS,STAR,NOT,INT_LITERAL,FLOAT_LITERAL,"true","false"
>>          [java] resources/swiftscript.g:1077:   between alt 1 and
>>     exit branch of block
>>     compileSchema:
>>          [java] Time to build schema type system: 0.973 seconds
>>          [java] Time to generate code: 0.524 seconds
>>          [java] Time to compile code: 4.389 seconds
>>          [java] Compiled types to:
>>     /global/u2/k/ketan/swift-devel/cog/modules/swift/../../modules/swift/lib/vdldefinitions.jar
>>     compileParams:
>>          [echo] [swift] Compiling mapper params compiler
>>          [echo] [swift] Generating mapping parameter classes
>>     dist:
>>     BUILD FAILED
>>     /global/u2/k/ketan/swift-devel/cog/modules/swift/build.xml:73:
>>     The following error occurred while executing this line:
>>     /global/u2/k/ketan/swift-devel/cog/mbuild.xml:18: fileset doesn't
>>     Total time: 8 seconds
>>     java is:
>>     /opt/java/jdk1.7.0_45/bin/java
>>     Any suggestions?
>>     Thanks,
>>     Ketan
>>     _______________________________________________
>>     Swift-devel mailing list
>>     Swift-devel at ci.uchicago.edu  <mailto:Swift-devel at ci.uchicago.edu>
>>     https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>     Justin M Wozniak
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20141218/0bc4c8f3/attachment.html>
