[Swift-devel] trunk fails to build on Edison
Ketan Maheshwari ketan at mcs.anl.gov
Thu Dec 18 09:27:56 CST 2014
Swift from trunk is failing to build on Edison with the following errors:
BUILD FAILED
/global/u2/k/ketan/swift-devel/cog/modules/swift/build.xml:355: fileset
doesn't support the "erroronmissingdir" attribute
Total time: 0 seconds
ketan at edison02:~/swift-devel/cog/modules/swift> ant dist
Buildfile: build.xml
generateVersion:
antlr:
     [java] ANTLR Parser Generator   Version 2.7.5 (20050128)   1989-2005
jGuru.com
     [java] resources/swiftscript.g:1077: warning:nondeterminism upon
     [java] resources/swiftscript.g:1077:     k==1:LBRACK
k==2:ID,STRING_LITERAL,LBRACK,LPAREN,AT,PLUS,MINUS,STAR,NOT,INT_LITERAL,FLOAT_LITERAL,"true","false"
     [java] resources/swiftscript.g:1077:     between alt 1 and exit branch
of block
compileSchema:
     [java] Time to build schema type system: 0.973 seconds
     [java] Time to generate code: 0.524 seconds
     [java] Time to compile code: 4.389 seconds
     [java] Compiled types to:
/global/u2/k/ketan/swift-devel/cog/modules/swift/../../modules/swift/lib/vdldefinitions.jar
compileParams:
     [echo] [swift] Compiling mapper params compiler
     [echo] [swift] Generating mapping parameter classes
dist:
BUILD FAILED
/global/u2/k/ketan/swift-devel/cog/modules/swift/build.xml:73: The
following error occurred while executing this line:
/global/u2/k/ketan/swift-devel/cog/mbuild.xml:18: fileset doesn't support
Total time: 8 seconds
java is:
/opt/java/jdk1.7.0_45/bin/java
Any suggestions?
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20141218/b94bd5cd/attachment.html>
