[Swift-devel] Returning float from java( ) no longer works
Michael Wilde wilde at anl.gov
Sun Apr 6 18:20:09 CDT 2014
I'm dusting off some old Swift code and running into errors which seem
to stem from changes in type checking and/or casting.
This used to work in a prior release (will need to track down which):
(float result) pow (float x, float y)
    result = java("java.lang.Math", "pow", x, y);
In trunk, it now gives:
Swift trunk swift-r7759 cog-r3890
RunID: run007
Could not start execution:
     Compile error in procedure invocation at line 50:
     You cannot assign value of type any to a variable of type float
(50 is line before result=...)
Any thoughts on why?
A similar error occurs on string results.
I'll file a ticket.
- Mike
