[Swift-devel] Returning float from java( ) no longer works
    David Kelly
    davidkelly at uchicago.edu
    Sun Apr  6 21:31:42 CDT 2014
In 0.95, this fails:
type file;
(float result) pow (float x, float y)
    result = java("java.lang.Math", "pow", x, y);
float f = pow(2.0, 2.0);
tracef("%f\n", f);
But when I replace java() with @java() it works for me...
On Sun, Apr 6, 2014 at 6:20 PM, Michael Wilde <wilde at anl.gov> wrote:
> I'm dusting off some old Swift code and running into errors which seem
> to stem from changes in type checking and/or casting.
> This used to work in a prior release (will need to track down which):
> In trunk, it now gives:
> Swift trunk swift-r7759 cog-r3890
> RunID: run007
> Could not start execution:
>      Compile error in procedure invocation at line 50:
>      You cannot assign value of type any to a variable of type float
> (50 is line before result=...)
> Any thoughts on why?
> A similar error occurs on string results.
> I'll file a ticket.
> Thanks,
> - Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140406/385dfc91/attachment.html>
