[Swift-devel] New built-in system, request for comments
Michael Wilde wilde at anl.gov
Sat Apr 5 23:54:45 CDT 2014
Nice, thanks, Yadu - this works great.
I see that "{ }" in the command line dont work yet - they are flagged as
invalid in the kml file.
But that's not a system( ) problem: you can't even put these characters
in a Swift string literal !
However "[a-d].data" passes through the kml fine.
- Mike
type file;
(string f[ ]) glob (string pat)
   f = system(strcat("/bin/ls -1 ",pat));
file dir[ ] <array_mapper; files=glob("f*.dat data*.txt")>;
foreach f in dir {
   tracef("file: %s\n", filename(f));
# gives:
file: data3.txt
file: data.txt
file: data4.txt
file: f4.dat
file: f1.dat
file: data1.txt
file: f3.dat
file: data2.txt
file: f2.dat
On 4/5/14, 10:51 PM, Yadu Nand Babuji wrote:
> I've committed the change for running the strings under bash, and
> wildcards
> and pipes are working. I can now do bash one-liners neatly and I like
> that.
> I tested with this :
> string o[] = system("ls *.swift");
> foreach t,i in o{
>     tracef("o=%s\n",o[i]);
> RunID: run021
> Progress: Sat, 05 Apr 2014 22:49:15-0500
> o=fail.swift
> o=system.swift
> o=shell.swift
> o=t.swift
> Final status:Sat, 05 Apr 2014 22:49:15-0500
> while system("echo *.swift"); returns a single line which goes to tracef.
> Like this :
> RunID: run022
> Progress: Sat, 05 Apr 2014 22:50:12-0500
> o=fail.swift shell.swift system.swift t.swift
> Final status:Sat, 05 Apr 2014 22:50:12-0500
> -Yadu
> On 04/05/2014 08:11 PM, Michael Wilde wrote:
>> As I alluded to in a prior post (but didnt say clearly), Im in favor
>> of giving system a varying number of returns, something like:
>> output = system("command");
>> (output,error) = system("command");
>> (output,error,rc) = system("command");
>> Also letting output and error be either strings or string arrays.
>> Not sure how much flexibility is best, though.
>> Regarding treating function failures like app failures: I dont think
>> thats good in the case of functions.  Further, in the case of apps,
>> we have at least one user request to provide more flexible error
>> handling for app failures. So when the user requests an rc (from
>> either), any non-zero RC should be returned to the user and not cause
>> the function (app or built-in) to be considered failed. Null files
>> can be returned to preserve dataflow semantics.  This is not totally
>> clear, and not clearly "best", but should should consider it.
>> Yadu, regarding the current implementation: I was about to send a
>> note to swift-user when I decided to test it first.  Im getting
>> strange errors when I try to do:
>> string o[] = system("echo *.swift");
>> tracef("o=%s\n",o[0]);
>> # produces:
>> o=*.swift
>> string o[] = system("sh -c 'echo *.swift'");
>> # produces:
>> swift:system returned exitcode :1
>> swift:system stderr:
>>  *.swift': -c: line 0: unexpected EOF while looking for matching
>> `''*.swift': -c: line 1: syntax error: unexpected end of file
>> Execution failed:
>> java.lang.IndexOutOfBoundsException: Invalid index [0] for o
>>     tracef @ system, line: 28
>> Caused by: java.lang.IndexOutOfBoundsException: Invalid index [0] for o
>> Yet:
>> string o[] = system("sh -c 'date'");
>> # produces:
>> o=Sat Apr  5 20:08:29 CDT 2014
>> So something strange is happening when I try to pass an argument with
>> shell wildcard chars to "sh -c".
>> I think that system( ) by default should send its args to "sh -c" so
>> that wildcards and all related shell features are available.
>> Lastly, note that in above, "echo" is just an experiment; what I
>> really want to do in this example is "/bin/ls -1 *.swift" for example.
>> - Mike
>> On 4/5/14, 7:01 PM, Yadu Nand Babuji wrote:
>>> Ketan,
>>> Do we need that ? If you add stdout, stderr and say exitcode as
>>> returns, the user has no
>>> choice but to define variables to hold those return values.
>>> Mihael mentioned in a separate thread that the behavior should be to
>>> fail early in case the
>>> executed string returns a non-zero exitcode.
>>> -Yadu
>>> On 04/04/2014 10:58 PM, Ketan Maheshwari wrote:
>>>> Is it possible to handle stdout and/or stderr of system("command")
>>>> separately? That way, it might be useful in other places as well.
>>>> On Fri, Apr 4, 2014 at 12:08 PM, Yadu Nand <yadudoc1729 at gmail.com
>>>> <mailto:yadudoc1729 at gmail.com>> wrote:
>>>>     Hi,
>>>>     I have just added a new builtin "system" to trunk. It takes a
>>>>     string,
>>>>     which is executed in the shell
>>>>     by java and the results are returned as an array. This is done
>>>>     to make
>>>>     mappings easier, for example,
>>>>     you can map an entire folder "foo" using the following :
>>>>     file folder[ ] < array_mapper; files = system ("find foo -type
>>>>     f") >;
>>>>     If the execution of the string provided fails, the logger would
>>>>     report
>>>>     the the exitcode and stderr to
>>>>     the swift stdout.
>>>>     Thanks,
>>>>     Yadu Nand B
>>>>     _______________________________________________
>>>>     Swift-devel mailing list
>>>>     Swift-devel at ci.uchicago.edu <mailto:Swift-devel at ci.uchicago.edu>
>>>>     https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>> Michael Wilde
>> Mathematics and Computer Science          Computation Institute
>> Argonne National Laboratory               The University of Chicago
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20140405/e91fafab/attachment.html>
