[Swift-devel] Cant get auto-coasters to run from midway to beagle
Mihael Hategan hategan at mcs.anl.gov
Sat Mar 9 15:56:36 CST 2013
Can you post ,globus/coasters/coaster.log from beagle?
On Sat, 2013-03-09 at 15:46 -0600, Michael Wilde wrote:
> Mihael, can you advise on this problem?
> David and I are trying to run automatic coaster jobs from midway login hosts and swift.rcc to beagle using ssh-cl:pbs.
> My failed attempts are on midway under /home/wilde/osgdemo/modis/svn, see eg run020 (which has complete logs).
> Quick question about the proxy files that get copied. Does this look OK? :
>   2013-03-09 21:24:46,895+0000 INFO  AutoCA Checking certificate /home/wilde/.globus/coasters/proxy.0.pem
> 2013-03-09 21:24:46,967+0000 INFO  AutoCA Using certificate /home/wilde/.globus/coasters/proxy.0.pem with expiration date Sat Mar 23\
>  19:25:53 GMT 2013
> The proxy expiration time listed above is two hours *earlier* than the current time (as seen in the message's UTC timestamp).  Is that correct, or a possible cause of this problem?
> The main symptom seems to be this:
> Execution failed:
> 	Exception in getlanduse:
>     Arguments: [../data/modis/2002/h00v09.rgb]
>     Host: beagle
>     Directory: modis01-20130309-2124-7ua3bde3/jobs/d/getlanduse-d24rhd6l
> Caused by:
> 	Could not submit job
> Caused by:
> 	Could not start coaster service
> Caused by:
> 	Task ended before registration was received.
> Failed to download bootstrap jar from http://midway001.rcc.uchicago.edu:50001
> Yet Ive verified that midway login4 (which is the target system) can connect to this hostname and port (with nc -l and telnet)
> - Mike
