[Swift-devel] Cant get auto-coasters to run from midway to beagle
Michael Wilde wilde at mcs.anl.gov
Sat Mar 9 15:59:22 CST 2013
I think we just got this working. Problems may have included the need to pre-create the workdirectory and to specify a dotted IP address on the external network for GLOBUS_HOSTNAME.  Will need to experiment.  So likely that proxy expiration time was not a problem (although its confusing).
Will report back on this once the needed steps are clear.
- Mike
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Saturday, March 9, 2013 3:56:36 PM
> Subject: Re: Cant get auto-coasters to run from midway to beagle
> Can you post ,globus/coasters/coaster.log from beagle?
> On Sat, 2013-03-09 at 15:46 -0600, Michael Wilde wrote:
> > Mihael, can you advise on this problem?
> > David and I are trying to run automatic coaster jobs from midway
> > login hosts and swift.rcc to beagle using ssh-cl:pbs.
> > My failed attempts are on midway under
> > /home/wilde/osgdemo/modis/svn, see eg run020 (which has complete
> > logs).
> > Quick question about the proxy files that get copied. Does this
> > look OK? :
> >   2013-03-09 21:24:46,895+0000 INFO  AutoCA Checking certificate
> >   /home/wilde/.globus/coasters/proxy.0.pem
> > 2013-03-09 21:24:46,967+0000 INFO  AutoCA Using certificate
> > /home/wilde/.globus/coasters/proxy.0.pem with expiration date Sat
> > Mar 23\
> >  19:25:53 GMT 2013
> > The proxy expiration time listed above is two hours *earlier* than
> > the current time (as seen in the message's UTC timestamp).  Is
> > that correct, or a possible cause of this problem?
> > The main symptom seems to be this:
> > Execution failed:
> > 	Exception in getlanduse:
> >     Arguments: [../data/modis/2002/h00v09.rgb]
> >     Host: beagle
> >     Directory:
> >     modis01-20130309-2124-7ua3bde3/jobs/d/getlanduse-d24rhd6l
> > Caused by:
> > 	Could not submit job
> > Caused by:
> > 	Could not start coaster service
> > Caused by:
> > 	Task ended before registration was received.
> > Failed to download bootstrap jar from
> > http://midway001.rcc.uchicago.edu:50001
> > Yet Ive verified that midway login4 (which is the target system)
> > can connect to this hostname and port (with nc -l and telnet)
> > - Mike
