[Swift-devel] Knowledge lab app on Midway using new swift-config
Ketan Maheshwari
ketan at mcs.anl.gov
Fri Dec 13 20:47:29 CST 2013
Cool. While we are at it, it might be of value to replace the
use.provider.staging=true with a simpler term. May be explicit.staging or
swift.staging ..
On Fri, Dec 13, 2013 at 8:14 PM, Yadu Nand <yadudoc1729 at gmail.com> wrote:
> Hi,
> I tried the new swift-config on Swift-0.95 RC1 on Midway today for a text
> processing app from the Knowledge lab.
> Here are some of the things I noted.
> 1. Config is super easy! This is all I had to do :
> site=westmere
> site.westmere.slurm.exclusive=false
> # App definition
> app.westmere.python=/usr/bin/python
> 2. Some settings were off when using my Swift-0.95 build. I had to module
> load swift and swift-conf, to get echo to be recognized as an app. Python
> still would throw the error "application "python" is not available for any
> site/pool in your tc.data catalog". This error should be corrected to point
> at swift.properties instead.
> 3. The .rlog file shows up the user directory. Can we have this to go to
> the run* dir.
> Occasionally .d folders also show up.
> 4. Why does a swift.log file show up in the user dir? It contains no
> useful info.
> Thanks,
> Yadu
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131213/5254b201/attachment.html>
