[Swift-devel] Knowledge lab app on Midway using new swift-config
Justin M Wozniak wozniak at mcs.anl.gov
Sat Dec 14 10:24:46 CST 2013
I think it's best to make properties hierarchical, like
data.staging.mode=provider
On 12/13/2013 07:47 PM, Ketan Maheshwari wrote:
> Cool. While we are at it, it might be of value to replace the
> use.provider.staging=true with a simpler term. May be explicit.staging
> or swift.staging ..
> On Fri, Dec 13, 2013 at 8:14 PM, Yadu Nand <yadudoc1729 at gmail.com
> <mailto:yadudoc1729 at gmail.com>> wrote:
>     Hi,
>     I tried the new swift-config on Swift-0.95 RC1 on Midway today for
>     a text processing app from the Knowledge lab.
>     Here are some of the things I noted.
>     1. Config is super easy! This is all I had to do :
>     site=westmere
>     site.westmere.slurm.exclusive=false
>     # App definition
>     app.westmere.python=/usr/bin/python
>     2. Some settings were off when using my Swift-0.95 build. I had to
>     module load swift and swift-conf, to get echo to be recognized as
>     an app. Python still would throw the error "application "python"
>     is not available for any site/pool in your tc.data catalog". This
>     error should be corrected to point at swift.properties instead.
>     3. The .rlog file shows up the user directory. Can we have this to
>     go to the run* dir.
>     Occasionally .d folders also show up.
>     4. Why does a swift.log file show up in the user dir? It contains
>     no useful info.
>     Thanks,
>     Yadu
>     _______________________________________________
>     Swift-devel mailing list
>     Swift-devel at ci.uchicago.edu <mailto:Swift-devel at ci.uchicago.edu>
>     https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131214/b68d7354/attachment.html>
