[Swift-devel] trunk execution fails with absolute path
Ketan Maheshwari ketancmaheshwari at gmail.com
Thu Aug 29 14:59:14 CDT 2013
Hi Mihael,
This works now. Just a note that I see status ticker showing every second
instead of every 30 seconds.
Ketan
On Tue, Aug 27, 2013 at 8:50 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Should be fixed now. Please give it a try and let me know if it works.
> On Mon, 2013-08-26 at 20:31 -0500, Ketan Maheshwari wrote:
> > Just a note that I tested the same configuration with 0.94 which works.
> > On Mon, Aug 26, 2013 at 8:28 PM, Ketan Maheshwari <
> > ketancmaheshwari at gmail.com> wrote:
> > > Hi,
> > > I notice the execution fails in trunk when providing absolute path for
> a
> > > file. I tested this with a catsn example. When providing relative
> path, it
> > > works. The mode is coasters, local:slurm on midway.
> > > Error message is as follows:
> > > Execution failed:
> > > Exception in cat:
> > >     Arguments:
> [__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/data.txt]
> > >     Host: midway
> > >     Directory: catsn-20130827-0122-c0vppi56/jobs/d/cat-dpf6fdel
> > >     exception @ swift-int-staging.k, line: 159
> > > Caused by: Job failed with and exit code of 1
> > > org.globus.cog.abstraction.impl.common.execution.JobException: Job
> failed
> > > with and exit code of 1 (exit code: 1)
> > >     at
> org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
> > >     at
> org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
> > >     at
> org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
> > >     at
> org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
> > >     at
> org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
> > >     at
> org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
> > > Caused by:
> failed
> > >     at
> > >     at
> > >     at
> > >     at
> > >     at
> > >     at
> > > Log for this run is:
> > > http://www.mcs.anl.gov/~ketan/absolutepath.log
> > > Thanks for any suggestions on fixing this.
> > > Regards,
> > > Ketan
> > works.
> > <ketancmaheshwari at gmail.com> wrote:
> >         Hi,
> >         path for a file. I tested this with a catsn example. When
> >         providing relative path, it works. The mode is coasters,
> >         Execution failed:
> >         Exception in cat:
> >             Arguments:
> >             Host: midway
> >             Directory:
> >         Job failed with and exit code of 1 (exit code: 1)
> >             at
> >             at
> >             at
> >             at
> >             at
> >             at
> >         Caused by:
> >             at
> >             at
> >             at
> >             at
> >             at
> >             at
> >         Regards,
> >         Ketan
> > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130829/77379b6a/attachment.html>
