[Swift-devel] trunk execution fails with absolute path
Mihael Hategan
hategan at mcs.anl.gov
Sat Aug 31 14:56:09 CDT 2013
The ticker should not be fixed.
Mihael
On Thu, 2013-08-29 at 14:59 -0500, Ketan Maheshwari wrote:
> Hi Mihael,
> This works now. Just a note that I see status ticker showing every second
> instead of every 30 seconds.
> Thanks,
> Ketan
> On Tue, Aug 27, 2013 at 8:50 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > Should be fixed now. Please give it a try and let me know if it works.
> > On Mon, 2013-08-26 at 20:31 -0500, Ketan Maheshwari wrote:
> > > Just a note that I tested the same configuration with 0.94 which works.
> > > On Mon, Aug 26, 2013 at 8:28 PM, Ketan Maheshwari <
> > > ketancmaheshwari at gmail.com> wrote:
> > > > Hi,
> > > > I notice the execution fails in trunk when providing absolute path for
> > a
> > > > file. I tested this with a catsn example. When providing relative
> > path, it
> > > > works. The mode is coasters, local:slurm on midway.
> > > > Error message is as follows:
> > > > Execution failed:
> > > > Exception in cat:
> > > > Arguments:
> > [__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/data.txt]
> > > > Host: midway
> > > > Directory: catsn-20130827-0122-c0vppi56/jobs/d/cat-dpf6fdel
> > > > exception @ swift-int-staging.k, line: 159
> > > > Caused by: Job failed with and exit code of 1
> > > > org.globus.cog.abstraction.impl.common.execution.JobException: Job
> > failed
> > > > with and exit code of 1 (exit code: 1)
> > > > at
> > org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
> > > > at
> > org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
> > > > at
> > org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
> > > > at
> > org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
> > > > at
> > org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
> > > > at
> > org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
> > > > Caused by:
> > failed
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > Log for this run is:
> > > > http://www.mcs.anl.gov/~ketan/absolutepath.log
> > > > Thanks for any suggestions on fixing this.
> > > > Regards,
> > > > Ketan
> > > works.
> > > <ketancmaheshwari at gmail.com> wrote:
> > > Hi,
> > > path for a file. I tested this with a catsn example. When
> > > providing relative path, it works. The mode is coasters,
> > > Execution failed:
> > > Exception in cat:
> > > Arguments:
> > > Host: midway
> > > Directory:
> > > Job failed with and exit code of 1 (exit code: 1)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Caused by:
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Regards,
> > > Ketan
> > > Ketan
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Hi Mihael,
> second instead of every 30 seconds.
> Thanks,
> Ketan
> it works.
> which works.
> > > Hi,
> absolute path for a
> relative path, it
> > > Execution failed:
> > > Exception in cat:
> > > Arguments:
> > > Host: midway
> > > Directory:
> Job failed
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Caused by:
> Job failed
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Regards,
> > > Ketan
> which
> > works.
> > Hi,
> absolute
> When
> coasters,
> > Execution failed:
> > Exception in cat:
> > Arguments:
> > Host: midway
> > Directory:
> > at
> > at
> > at
> > at
> > at
> > at
> > Caused by:
> > at
> > at
> > at
> > at
> > at
> > at
> > Regards,
> > Ketan
> > Ketan
> Ketan
