[Swift-devel] trunk execution fails with absolute path
Mihael Hategan
hategan at mcs.anl.gov
Tue Aug 27 20:50:11 CDT 2013
Should be fixed now. Please give it a try and let me know if it works.
On Mon, 2013-08-26 at 20:31 -0500, Ketan Maheshwari wrote:
> Just a note that I tested the same configuration with 0.94 which works.
> On Mon, Aug 26, 2013 at 8:28 PM, Ketan Maheshwari <
> ketancmaheshwari at gmail.com> wrote:
> > Hi,
> > I notice the execution fails in trunk when providing absolute path for a
> > file. I tested this with a catsn example. When providing relative path, it
> > works. The mode is coasters, local:slurm on midway.
> > Error message is as follows:
> > Execution failed:
> > Exception in cat:
> > Arguments:
> > [__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/data.txt]
> > Host: midway
> > Directory: catsn-20130827-0122-c0vppi56/jobs/d/cat-dpf6fdel
> > exception @ swift-int-staging.k, line: 159
> > Caused by: Job failed with and exit code of 1
> > org.globus.cog.abstraction.impl.common.execution.JobException: Job failed
> > with and exit code of 1 (exit code: 1)
> > at
> > org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
> > at
> > org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
> > at
> > org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
> > at
> > org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
> > at
> > org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
> > at
> > org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
> > Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
> > at
> > at
> > at
> > at
> > at
> > at
> > Log for this run is:
> > http://www.mcs.anl.gov/~ketan/absolutepath.log
> > Thanks for any suggestions on fixing this.
> > Regards,
> > Ketan
> works.
> <ketancmaheshwari at gmail.com> wrote:
> Hi,
> path for a file. I tested this with a catsn example. When
> providing relative path, it works. The mode is coasters,
> Execution failed:
> Exception in cat:
> Arguments:
> Host: midway
> Directory:
> Job failed with and exit code of 1 (exit code: 1)
> at
> at
> at
> at
> at
> at
> Caused by:
> at
> at
> at
> at
> at
> at
> Regards,
> Ketan
> Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
